Issue Resizing Part
Hi,
I have imported a Part into Onshape, then created a new sketch of the part. Meanwhile, I am having issues resizing the part. Selecting the Dimensions Button does not enable the feature.
Thank you.
Joseph
  • _Ðave_
    _Ðave_ Member, Developers Posts: 712 ✭✭✭✭
    edited January 2016
    Scaling on a part is accomplished by the transform tool.
  • joseph_fournier
    joseph_fournier Member Posts: 17 ✭
    Thank you. Isn't possible to resize it using the Dimensions Functionality found in the sketch design?
  • _Ðave_
    yes, Just double click any dimension in the sketch and type a new value. HTH
    _Dave_
  • joseph_fournier
    I would like to, but upon clicking the Dimension button in a newly created sketch of an existing part and selecting an edge, the Dimensions (length) are not being displayed, as demonstrated in Onshape's Tutorials.
  • _Ðave_
    sounds like there is a problem and you need to send feedback to onshape and request a support ticket.
    _Dave_
  • joseph_fournier
    Thank you for your time!
  • joseph_fournier
    I have tested the functionality using a newly created sketch (a non-imported 3D part as in the previous case) in the same document and everything is working properly. I believe that there must be some constraints existing on the imported part, which prohibits me from modifying its dimensions.
  • _Ðave_
    If you used the use function to create the sketch the it would be constrained to the solid part.
    I you share a link and explain what you are attempting to do, I'll have a look.
    _Dave_
  • joseph_fournier
    Thank you. I am new to Onshape, and thus most likely I am not using the software as it should be. The Part I am trying to resize can be found at the following link. After activating Edit on Sketch 1, I am trying to resize the components of the Part using the Dimension functionality, but without success.
    https://cad.onshape.com/documents/1c1bd57501f058d79fd4d193/w/fe93ebe587bc64ea153ecd07/e/e64b7a3a00b5f3537703a606
    Thank you again.
    Joseph
  • joseph_fournier
    Thank you both for your help.
    Joseph
