Merging edges
graham_lock
graham_lock Member Posts: 277 PRO
edited October 2024 in FeatureScript
Hi,
I'm trying to find a way to merge edges into a single edge for processing but haven't managed to find a way. I thought maybe composite curves would help but I haven't found a way to make them work.
In essence I have flat parts which will have one vertical side and one curved side. If the curved edge is created form a spline then a single edge is created which is what I need. If the curved edge is created from a combination of sketch objects such as lines, arcs and splines then of course multiple edges are generated.
The test document shows what I'm trying to achieve, this is based on previous help provided by @NeilCooke
https://cad.onshape.com/documents/51321e4200a10909a4edcdbc/w/e0fd06e21dbd3430bffea7e5/e/92f92db270bf9c050630f2a7
Any help appreciated.
Thank you.
