Is it possible to disable the automatic "suggestions" for the merge scope of a hole?
When I add a hole, OnShape will auto-populate the merge scope of that hole. Sometimes this is useful, other times it extends the merge of the hole well beyond what I want it to be, which can be frustrating to have to delete multiple items from the merge scope list when I just want the hole to go all the way through one or two parts, not every part that hole could theoretically touch in a continuous straight line.
Further, there have been multiple times where I've gone in to edit the parameters/dimensions/etc of a hole, and after making those edits, the merge scope changes itself to include more parts. This is incredibly frustrating and has led to multiple instances where that change in merge scope causes problems in other parts that I don't catch until much later into the design process (one time after a small edit request by a machinist almost led to a catastrophe when that hole change edited multiple parts it wasn't previously set to edit).
Is there a way to turn this off? I'd much rather just have to manually select the relevant parts every time I make a hole instead of risking these problems.
  • J_Taylor
    J_Taylor Member Posts: 1 PRO
    Please onshape work on this! It's beyond irritating and really slows down preview times when it keeps selecting complicated objects to put holes in during feature creation and edit - doing it during edits is extra frustrating as I'm constantly deleting the same selection and i really don't need an auto suggestion for something i've already gone through and selected
  • john_mcclary
    I absolutely want Onshape's "smart" features to be deleted from the code.
    More often than not it gets is the way. Like they way it will change from New to Add or Remove in extrude. I start selections from the top, then and work my way down the feature list, just to go back up to the top and re-select the boolean option I wanted.
    The tapped hole merge scope got me a month ago.
    I added a logo sign to a guard just before release, then one of the tapped holes blew through all the parts and I didn't catch that.
    So they actually manufactured all the parts with that random hole cut through the hole machine's internal guts.
    The green circles are what I needed holes for. The red are the parts that got made wrong.
    Reminded me of those construction fail memes where they thing a revision cloud is an object line
