Taper/Draft
Trying to model the below. Will be tapered in 2 directions.
Got the taper from bottom to top by using draft. Goes from 33mm to 26mm.
Now in the below image, I need the taper to go from 80mm back from front edge from the 26mm down to 16mm. This will start from the point vertically below the line on the isometric view. Is this possible.
Link to model.
https://cad.onshape.com/documents/60b6c005a80598c89bdecdfe/w/cea2cbde586f167e7be3d611/e/e8bd9ee0a01fd174ad3a1bc8
New to onshape.
Thanks
