Where are US servers?
Is there a cluster south of the northeast? Or are they all west coast for the US? Not sure where my connection stutters and forgets to load... close to trying to teach with it...
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 422 image
    The latency from anywhere in the US to us-west-2 (Oregon) is easily low enough for CAD work. If your connection stutters or forgets to load, that's a different issue. You should look at your machine and local network. Are you seeing this same behavior on all the machines you are using?
    Your latency and GPU metrics look fine from my POV.
    John Rousseau / VP, Technical Operations / Onshape Inc.
  • S1monS1mon Member Posts: 4,063 PRO
    edited December 2024
    According to this help page, there's just the US-West. There are some instructions on how to help investigate/resolve latency issues.
    https://cad.onshape.com/help/Content/performance.htm#CommonCausesLag
  • nelson_raney619nelson_raney619 Member Posts: 5 EDU
    well getting errors on something that loaded fine a second ago… seems about the same on other machines in this neighborhood.
    That has nothing to do with servers and everything to do with your document. Open the last known good state by right-clicking the document on the documents page, select Versions and history, then "view" (from 3 dot menu to the right) a previous microversion.
    Well it seems to be an intermittent issue, at least it will load showing everything broken now, but it wasn't earlier… Several broken bits seem to take over a minute to load, but now they are broken. Should I get more server time? auto desk and solid works don't like this style of part at all…
