Sketch: how to find, select and remove identical entities drawn on top of each other?
I have a sketch with duplicate entities drawn on top of each other. How to identify these so I can remove these?
I am familiar with the select other options, but I deal with sketched that have 100+ line entities, some are drawn 4 times on top. I like to quickly find all automatically, not having to select each one at the time. Does Onshape have an option for this. I believe I use to have this option in SolidWorks under sketch tools.
I can't think of a specific tool for this but sometimes the left-to-right rectangle selection can help. It will grab only items fully inside the selection box, not ones that overlap the box.
2 -
Matts suggestion is best so long as the end points don't line up with other endpoints. π€¬π€£
Thanks, but that does not offer a solution. Unfortunately, I am talking about identical entities, with identical endpoints. And many of these.
@Gerard I assume these are imported sketches? You could process them in another tool. ARES Kudo (available as a paid add-in for Onshape) apparently has a command called DiscardDuplicates:
https://kudo.graebert.com/help/additional/hlpid_edit_discardduplicates.htm(I've never used this command, and as a non-AutoCAD users, ARES makes me very cranky to try to use, but I could see depending on your needs, it might be well worth the cost/effort.)
Thanks all for your feedback. It has answered my question, Onshape does not offer a solution. It would be nice to see this feature added.
As a side note, if the entities are actually duplicates, Onshape doesn't really care as it should still be able to use the regions (for solid operations) or edges for surface/thin features.
I guess I'm asking what workflow you need to remove the duplicates forβ¦
Thanks Eric, I know, but the sketch is used as driving, configured sketch, so needs to be in perfect condition. I have manually cleaned it all up, I just found the issue to be a possible improvement in Onshape. A nice to have . . . π
Nothing automatic.
The rare times I've run into this, I select the line and press delete, then repeat, until there is no line on the screen. Then I press the undo button once to get the last line back. Repeat with the other duplicate lines.
1 -
Hence my suggestion for improvement . . . π
Make an Improvement Request. I'll vote for it. π
