an extrude doesn't cut through a frame part
ittay_dror
Member Posts: 4 ✭
in General
https://cad.onshape.com/documents/59166254d507fca000ac3cd7/w/ecfbac350ba8c6e5938c1104/e/ebc49168a4e7e40663092b39?renderMode=0&uiState=67d1e27ff693b77b5f602df8
the last step is a remove extrude through all where 4 parts are in scope. it cuts through 2 but only partially cuts through the other two
Have you fixed this? The last extrude cuts through all the parts you have in your merge scope. Which extra parts do you want cut?
