how do I insert Onshape sketch into Draftsigtht?
jackie_1
Member Posts: 20 EDU
When I inserted my Onshape 2d sketch into a Draftsight template, it did not get put it in the same layer. Did I do something wrong?
Hi Jackie, you probably needed to set "cut" as the current layer in DraftSight before importing the Onshape DWG. Onshape does not have layers so you can't do it upfront. See this link to move the objects to another layer (it is AutoCAD but should be very similar): http://www.cad-notes.com/3-ways-to-move-autocad-objects-to-other-layer/
Senior Director, Technical Services, EMEA5
21 views, no comments. I was wondering if I needed to clarify. Do any of the viewers have a question?
Thank you for your answer.Yes, I want to draw a sketch in part studio in Onshape, save as a dwg, and then insert the sketch into the template CELERE 2016 TESTCELL TEMPLATE found at this url: https://spaceflightsystems.grc.nasa.gov/education-outreach/celere/how-to-apply/ because Onshape is so much easier to use than Draftsight. Is there any way to do this? I thought I drew, saved, and inserted the sketch correctly but the CELERE program person said the Onshape sketch was not inserted into the "cut" layer of the Draftsight template. Any help understanding what is going on would be greatly appreciated. I am a novice user.
Senior Director, Technical Services, EMEA5 -
Oooh, I will look into this! Thanks!! I will leave this as a "not answers" for a few more hours....
still processing....
still processing. I think this is over my head.
