3D printing - Where do I start?
I've made a part to be 3D printed, however I don't know if I need to change the infil now (in the design studio in onshape) or later. once that's done then what file type do i export it as (I'm using a Creality ender 3 pro 3D printer)
Any kind of help would be much appreciated.
Here's a picture of the thing I'm printing for reference:
Export to STL and set the infill with your slicer software.. youtube can help you sort out slicer settings
1 -
Do you have any recommendations for a slicer software?
Most start with Cura it seems. I'm moving to Bambu Studio
1 -
The infill is usually added in the slicer. I have Prusa printers and use Prusa Slicer. The Prusa Help site has tons of info on slicing, settings, etc.
1 -
Where do you need infil, rotate the part 180 degrees and you don't need infill.
Just a stupid question
-1 -
You are thinking 3D-print supports, I suspect. Infill is the percent of an enclosed part that is filled "in" with filament. 100% infill on a sphere would be 100% (solid) filament inside the sphere, for example. Infill can be specified in a wide variety of geometric forms.
The software that came with your printer is usually the first choice.
1
