house help needed
https://cad.onshape.com/documents/5e0aad5338049d58e998649d/w/4329a036c2204f750e842286/e/cc4f8ca8c6a8753bb66f7bdf?renderMode=0&uiState=67e60a11f2c902141a6ae0e7Error
hello all
this is a house i am working on for a school project and i am not sure how to solve the errors if anyone can assist please comment your email and i will give access.
this is my 1st year using Onshape and i have done tons of toruble shooting but i am.having trouble with the rest of the errors..
thank you
  • martin_kopplow
    Almost all your sketches are underconstarined - fix that first. Make sure all things you want to be a face are really fully closed.
    Extrude 23: No face selected, or the face selected was removed after you created the extrusion.
    Sketch 17: There is one point way off (zoom out!) that has lost it's refernce. You probably removed something that was in fact still needed.
    Almost all following sketches and extrudes: Same issue as with Sktch 17.
    Warm hint:
    1. If you want to create a building, fist make drawing planes that represent the floors and/or ceilings. Fix these! Then use these planes to base your wall sketches on, NOT faces of tentative/temporary objects subjcet to be deleted in the process.
    2. Go to the Learning Center and learn the basics first.
  • MDesign
    sketch1 is SUPER "sketchy".
  • ari_goodman868
    ari_goodman868 Member Posts: 6 ✭
  • MDesign
    you've already given access. but you have not identified exactly what your trying to do and what errors your trying to fix. You will have to go into more detail if you want others to help you trouble shoot.
  • ari_goodman868
    all of the remaining errors
    sketch 10, 14, 27, 33, 36, 39, 40, 42,
    extrude, 26, 11, 25, 13, 22, 45
    revolve,1
  • MDesign
    If you open the features it tells you an error like this. in the case of sketch 10 and some others it looks like you changed something about Extrude 1 that caused sketch 10 to lose its connection to Extrude 1 face.
  • MDesign
    edited April 2025
    In your original document it looks like you edited extrude 1 on 3/17 @ 9:57 PM. This edit broke sketch 1. It looks like you deleted all of the sketch regions that extrude 1 was referencing to make extrude 1.
    Link to the point in history to your original document before sketch 1 was broken..
    https://cad.onshape.com/documents/f3cad8d495cda10c46d5c439/w/ad0459ea25c3d7b406510819/m/65d351bfd1b2245d9d873353/e/cba83e88766abcc300009914
    You can use the history to troubleshoot what went wrong and when it happened.
