Imported an STL part but cannot design on it
jan_zbornik
jan_zbornik Member Posts: 2 EDU
Hi all,
I have imported an STL file and would like to design on top of the existing part. However, I cannot create a sketch or plane. Is there a way to start designing with imported STL parts?
https://cad.onshape.com/documents/6f55735ce66509a8c699983a/w/4ce2f74ec467536bab770c04/e/2f7dec09e4a8593b8834f510?renderMode=0&uiState=6812c666b1ef2e365cb23101
  • MDesign
    create a plane with 3 point method. Sketch on the plane
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,379 PRO
    Try constrained surface to enclose all as a solid.
    Would have tried on your document but it was view only. If you intended other then it wants to be made public for copying.
  • MDesign
  • glen_dewsbury
  • EvanReese
    EvanReese Member, Mentor Posts: 3,096 PRO
    Sounds like you already got your answer, but wanted to chime in to say that if your goal is modifying this part, it looks simple enough to recreate using the mesh as a reference. That would give you a lot of flexibility. If you just want to add to it or cut a little bit away, then carry on with a mixed modeling approach.
