Improvements to Onshape - May 16th, 2025
NeilCooke
NeilCooke Moderator, Onshape Employees Posts: 6,078 image
edited June 2025 in New in Onshape
This is the second of two releases to focus on stability and performance, but we have still managed to find the time to throw in some super cool and highly requested new features.
VISUALIZATION
ISOLATE AND MAKE TRANSPARENT
The Isolate and Make transparent tools now include a slider to adjust transparency. An option to select transparent geometry enables both tools to be used effectively when interacting with both transparent and opaque geometry.
https://onshape.wistia.com/medias/61fvertep9?embedType=web_component&seo=true&videoWidth=960
PART STUDIOS
REPLACE FACE
The Replace face feature now accepts more than one face as a replacement, enabling more complex results with a single feature.
https://onshape.wistia.com/medias/8ey89qru42?embedType=web_component&seo=true&videoWidth=960
PUBLICATIONS
INSERT RELEASED PARTS
Released parts can now be added individually to a Publication. This removes any other parts in the Part Studio, reduces clutter and ambiguity, and protects intellectual property.
https://onshape.wistia.com/medias/8jcpxqvzc2?embedType=web_component&seo=true&videoWidth=960
GENERAL
RESUME LAST LOCATION
After a period of inactivity, the current Onshape session may be signed out. Signing back in will resume the last session, either opening the last active Document, navigating to the last open folder, or showing the last search results.
https://onshape.wistia.com/medias/gtlq5b2sul?embedType=web_component&seo=true&videoWidth=960
SORT FOLDERS IN "MOVE TO..." DIALOG
When moving Documents, Publications and Folders using the "Move to..." context menu, the list of Projects and Folders can now be sorted alphabetically or by Last modified for easier navigation.
ONSHAPE VISION
CONNECT MULTIPLE DOCUMENT TABS
Multiple Onshape Document tabs can now be shared from the Onshape mobile app on an iOS device to the Onshape Vision app on Apple Vision Pro. After a Document is shared, return to the Documents page and all shared Documents will be listed in the dialog as shown below. The Document will still be viewable in Onshape Vision even though it has been closed on Onshape mobile. Open one or more further Documents and share with the Onshape Vision app. All Documents will be shown and available to view on the Onshape Vision Documents page.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.
