Decrease the size of a sweep
biel_sugrañesbiel_sugrañes Member Posts: 2
How can I progressively decrease the size of a sweep in OnShape?
Beacouse I want to build a handle for a vase, but the handle must be progressively decreasing.
  • MDesignMDesign Member Posts: 1,297 PRO
    loft with a path
  • afalzate13afalzate13 Member Posts: 54 PRO
    control the end point of the path through a variable like a spline that attaches to the sketch end point. Then use the Loft tool and you can control the extent of the handle that way through the variable.
