Why my table legs not the same, if measures are?
arnis_vingris
Member Posts: 6 ✭
Hej. I made table today, and i used loft to make table legs, on one side of the table it makes legs one way, and on oposite side other two legs are different, how to fix this.
Name of document galdsaarnija
glen_dewsbury
Member Posts: 1,257 PRO
There are some sketches in the original that are not aligned and matched with other sketches. The loft is twisting the legs because of this.
Attached are a couple of samples that you may find useful.
Better to mirror parts than to draw individually in sketches.
Assembly will give BOM part count instead individual name/part number to repeat parts.
glen_dewsbury
This was the first one I saw. All others are base on 90x90 squares. The constraints are not working out.
The loft is twisting due to the connection points it's using.
I assume this document? https://cad.onshape.com/documents/6a724d75617326e4de0a98dc/w/0557e2d7f23f0440b3895a63/e/90ef26e05d56d7f8898e944a
Yes that is that document.
Meassurements are identical on both sides.
https://cad.onshape.com/documents/bc77422bae424ecbdaf2e389/w/0afd12a8963b6dccb67d28d9/e/5112a20df13e9af2f82fefba
