How to Make a Plane Tangent to a Point on the Surface of a Ball
It's not actually a ball, but I believe this is the same problem. I'm just trying to drill straight into a curve, and/or to make a plane tangent to the curve in the process. None of the plane types seem to work. (Selecting the curve and a point on it just stays red for "Tangent Plane". Point Normal comes out unrelated to the curve… It ends up parallel to the front plane for some reason. Curve Point plane is the closest I've gotten. Curve Point at least gives a result that is related to all of the input geometry, and I may be able to get there with further drawings and planes from that. But there muse be an easier way, no?
Thanks for any tips.
    S1mon Member Posts: 4,613 PRO
    edited November 2025
    One quick solution: add lines from the points to the center. Then you can easily create a hole feature using a mate connector on the end of the line.
    https://cad.onshape.com/documents/e7c5e0b836ec95210e8786f5/w/750ad5b90a511153db1d7333/e/1316d4a2fa31c143fc66d64e
  • MDesign
    Wouldn't it be cool if you could use a point to define a mate connector and then use another point to realign mate connectors primary/secondary axis? you can't but it would be cool and you wouldn't need to do what Simon says.
    Funny you mention that. I created an improvement request a while ago to reorient the secondary axis of a MC based on a secondary hole, but it would be nice to reorient the primary axis based on a vertex.
    https://forum.onshape.com/discussion/17956/realign-secondary-axis-of-mate-connector-to-a-hole-or-other-similar-features
  • jelte_steur_info
    since they're all coplanar, wouldn't it be better to just cut one hole, and use a circular pattern (axis at the orange point) for the second in the same protrusion, and then another circular feature pattern to copy those holes to the other protrusions?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,958 PRO
    You can do special transforms and alignments of a mate connector using @Konst_Sh's Multi Mate Feature.
    I use it all the time in special workflows for people.
    Yep. I love that feature, but not everyone knows how to find and add custom features, which is why I said the quickest fix was to just redefine one sketch and add a few lines.
  • MichaelPascoe
    We definitely need a better way to find and add custom features. Feature Store! The coolest part of Onshape is how you can customize it, and "no one" even knows you can do it until they start digging around on the forums. They see the app store button, there should be a feature store button right up top.
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,162 PRO
    I'm even starting to lose track of my own features that I've developed. Onshape needs their own Features Nexus.
  • jeffrey_hawkins
    jeffrey_hawkins Member Posts: 22 EDU
    S1mon's suggestion seems straightforward enough. I've solved the original issue by just making a series of planes that got me there. But the same thing just came up in a different context. So here goes…
    Thanks all.
