onshape cant export
I've been trying to export a STEP file from Onshape, but it doesn't download
We are currently investigating. Follow for updates.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com2 -
step files are not exporting for me right now.
PDF export not working too.
I see that a fix has been implemented. Just to let you know, I am able to import a step file that I couldn't previously (a bolt from McMaster), but some files still get stuck in "Uploading" or "Translate" (a PCB from Adafruit).
We can export STL's now but not STEP. The status states "A fix has been implemented and our team is monitoring.", however that's not completely accurate.
I am also having trouble exporting files. I select export and I get the popup that tells me the file is being prepared and I will get a notification when the file is ready to export. Nothing happens after that. Waiting does nothing. I never get a notification nor a download.
- Tried many different formats,
- different parts within a files,
- and different projects with different combinations of parts and formats
- Also tried exporting to One drive instead of downloading.
Getting a ton of these errors every couple of seconds now:
Onshape encountered a problem with your last operation. If the problem persists, contact support. Support code a42a3390f25d820101451115.
oh me too😥
I'm not sure if this is unrelated, but i am still experiencing this issue
