Configuration Payground Best usecases and Complex Examples and Dynamic suppression
https://cad.onshape.com/documents/d6b28e0ac64aa971f9ef66f9/w/4b40d7bd54e2f225eb3010b1/e/6449b5c7f17296baa0fcc81f
I am trying to make some dynamic configurable parts more parametric
Dynamic Suppression is pretty good. however how do you write a, Unsuppressed if [expression]
Unsuppressed if #is_Square = 1?? is there a equal to? value?
Unsuppressed if #is_Square >1 i can make it work.
Unsuppressed if #Name_ID = "ROUND"
just looking for some feedback and tips, guide lines to make a cleaner, more powerful configuration project. that is easy to control / maintain / update and user friendly to users to edit the configuration.
Senior Director, Technical Services, EMEA1
Senior Director, Technical Services, EMEA1 -
Thankyou Neil, i could not find same as or equal to ==
Dynamic Suppression is very cool and its very handy to place many features into a folder and then right click the folder to dynamic suppression.
its seems a lot smarter/easier using a folders to configure batch dynamic suppression(seems folder dynamic suppression is actually a batch suppression expression applied to the elements inside the folder) rather than setting up individual suppression states for each feature in the configuration panel.
However folder dynamic expressions seem broken that you can "add dynamic suppression" and it applies the dynamic suppression expression to everything in the folder. But if you want to "edit dynamic suppression" of a folder you cant, you have to first remove and then add again. However you are able to "edit dynamic expressions" of individual features in the folder.
things get quite complex very fast using complex suppression states, and dynamic expressions, etc. but the control you can get on dynamic parametric project is pretty cool.0
