How to create a "triangular extrusion" simply?
https://cad.onshape.com/documents/c9329f2ab9069ce41809af0a/w/4a07f3c9ab45999385886925/e/8d64d267667c224bab96d56c
I've linked 3 different attempts I've made at this. The first one just does a draft angle which is easiest but doesn't quite get it right.
The second one builds and chamfers 3 different extrudes which are then boolean joined, but the chamfer on the upper right of the 7 isn't quite right and fiddling with decimal places to get it "close enough" is not a fun workflow.
The last one uses lofts and thicken but requires an offset plane and projected geometry and a whole bunch of lofts because if I try to chain them it gets curvy and I want them straight walled/triangular..
