Improvements to Onshape - April 24, 2026
mlaflecheCAD
mlaflecheCAD Member, Onshape Employees, Developers Posts: 214 image
edited April 28 in New in Onshape
This update introduces a significant new cloud-to-cloud integration between Onshape PCB Studio and Altium 365, along with enhancements across CAD, MBD, and Data Management. It also includes a comprehensive new course to help you get started with CAM Studio, along with additional updates to the Learning Center. Let us proceed without delay.
PCB STUDIO
ALTIUM 365 INTEGRATION WITH ONSHAPE PCB STUDIO
Onshape PCB Studio connects directly to Altium 365 via cloud-to-cloud integration, eliminating the need for locally managed files.  Electrical and mechanical teams exchange board data, components, and design changes in real time using Altium credentials, and reusable MCAD libraries populate automatically from shared components.  See Altium integration for more information.
https://onshape.wistia.com/medias/txv6ulu1z0
CAD
MOVE MULTIPLE ROUTING CURVE CONTROL POINTS SIMULTANEOUSLY
Editing routing curves is now faster and more efficient, with the ability to select and move multiple control points at once using a precisely positioned triad. This enables cleaner, more consistent edits with fewer steps and greater control—especially for complex routing geometry.
https://onshape.wistia.com/medias/gl06j0koij
HIGHLIGHT PART WHEN EDITING IN-CONTEXT
When selecting a part in an assembly and choosing Edit In-Context or Switch to Part Studio, Onshape will now open that Part Studio with the chosen component selected and highlighted in the graphics area and Parts list of the Part Studio. This will save time by eliminating the need to find the component you wish to work on.
https://onshape.wistia.com/medias/li6q08s0gt
REDUCE MOUSE MOVE HOVER HIGHLIGHT
In Onshape’s continued effort to increase performance for complex models; now as you move over geometry rapidly, Onshape will delay highlighting that geometry. This will both make it less distracting and more performant as every entity hovered over no longer needs to appear on screen.
https://onshape.wistia.com/medias/w9znb4l4de
MODEL-BASED DEFINITION SUPPORT FOR CENTERLINE DIMENSIONS IN SKETCHES
Model-based definition supports centerline dimensions in sketches and provides full support for all sketched hole and shaft tolerance types.
https://onshape.wistia.com/medias/lcdhsljnkd
DATA MANAGEMENT
SUBFOLDER SHARING
Administrators can now share subfolders to users and teams with settings independent of their parent folder. This opens up new collaborative and organizational opportunities for companies, their designers, and even external participants of the design process.
When shared into a subfolder in this way, end users who do not have access to the parent folder can access these shared folders via the “Shared with me” button in the left-hand navigation of the Documents page.
https://onshape.wistia.com/medias/uyytggi0je
ADD TO RELEASE FROM OTHER DOCUMENTS IN A VERSION
It is now possible to add additional elements from other documents to a Release candidate, even when the Release candidate was initiated from an existing version. You can select from which version of these other documents the revision will be created in. Once approved, a revision is applied to all elements in their selected versions.
https://onshape.wistia.com/medias/my2uxlvtj3
DRAWINGS
HIGHLIGHT HOLE CALLOUTS ACROSS DRAWING VIEWS
You can now hover over hole callouts that utilize quantity on drawings to highlight all of the holes that the annotation references in Onshape.
https://onshape.wistia.com/medias/jruh2uzhdv
RENDER STUDIO
LIVE NAVIGATION
Render Studio continuously updates the rendered view as the camera moves, improving interactive performance and providing immediate visual feedback as you frame a shot or adjust the composition.
https://onshape.wistia.com/medias/cr0lbxxy61
LEARNING CENTER
INTRODUCTION TO CAM STUDIO
We are excited to announce that the Introduction to CAM Studio course has been updated! The refreshed introduction provides clearer guidance, streamlined navigation tips, and an overview of new features to help learners get started quickly and confidently.
LEARNING CENTER UPDATES
We have begun updating all Learning Center articles. The following have been completed so far, each translated into French, German, Spanish, and Japanese:
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update. Mobile app interface updates occur via the Apple App Store or Google Play Store and happen in the days following the update.
Regards,
Mike LaFleche   @mlaflecheCAD
    S1mon Member Posts: 4,609 PRO
    WOW.
    I really was not expecting the Altium integration to be so soon or so powerful. Really looking forward to trying this out with my new team.
    Also very excited to see all the other updates including the routing curve editing.
  • aeromorrison
    aeromorrison Member Posts: 92 PRO
    Solid updates! Especially excited about moving multiple routing curve control points and reduce mouse move hover highlight.
  • Chris_D_Mentes_001
    Chris_D_Mentes_001 Member, csevp Posts: 132 PRO
    Very nice, context part highlighting and delayed mouse hover delay are particularly useful for me.
    It'll make handovers easier of teams!
  • asher_collins049
    asher_collins049 Member Posts: 2 EDU
    The highlighting features are awesome, thank so much!
  • photinos_design
    photinos_design Member Posts: 3 PRO
    Thank you for adding subfolder sharing! I've been waiting for that one :)
  • EvanReese
    EvanReese Member, Mentor Posts: 3,090 PRO
    This is a real banger of a release! Subfolder sharing has come up often for my clients and is very welcome. Multi-point selection for Routing Curve is a big one for me (though I'd like the ability to rotate collections of points, not just translate). The Altium integration rightfully gets the headline spot. That's a BIG deal for interdisciplinary collab!
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,266 PRO
    The Altium integration looks really nice!
  • Stephan_Rivero_Schwinn
    Stephan_Rivero_Schwinn Member Posts: 4 PRO
    Could it be that the update deleted shared informations in documents.
    I got a lot of calls that they couldn`t find their work!
    The docs just shared with me or the engineer, no team or other ones any more!
    Just the admins can see everything.
    Is there a easy way to share many documents at once?
    If its working, it is a great value. So I didn`t need to share version in a pub.
  • daniel_konkel
    daniel_konkel Member Posts: 2 ✭
    Not sure why, but the highlight delay does not work for me. Neither for previously created nor newly created assemblies. Any ideas?
  • john_mcclary
    You may not be moving fast enough? It seemed the same for me at first, but you do notice it when you zip across the model.
    I assume it will be more noticeable on slower hardware. If you are getting snappy results. I think that's just a good PC that doesn't need to reduce the highlighting as much. ??
  • mlaflecheCAD
    edited April 27
    One thing I forgot to mention in the Altium connection video is that when you are using Onshape Professional or Enterprise, your Administrator needs to enable the connection in the integrations section of the company settings before it is then viewable in your personal account settings.
    Regards,
    Now that the framework is there for not highlighting items, is it possible to press a key sequence to turn off highlighting entirely? That would be helpful for presentations, when we just want to point to areas and have the mouse be the focus. I had a helpdesk request for this a few years ago, I may try to dig it out and reply to it.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,957 PRO
    edited April 27
    Those bounding boxes were driving me insane. Render Studio Live Navigation😍 is much appreciated.
    Going to go take the Introduction to CAM studio right now!
    Ty Onshape team!
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,929 PRO
    I just noticed that the "highlight all holes" of the callouts doesn't highlight across views (when using "count by part"). Not sure if that's supposed to be the case or not…
  • HARDWOODFP_ENGINEERING
    HARDWOODFP_ENGINEERING Member Posts: 42 PRO
    When are Sketch Blocks and Part Studio instancing coming? These are features that are still missing and 99% of the user base would welcome them and use extensively. While the announced updates, although really cool, are kind of niche.
  • EvanReese
    Subfolder permissions are extremely welcome! However I did have a client reach out because some of their team lost permissions to certain documents and I assume it was related. Fixing it was as easy as re-sharing, but could be inconvenient in a large org. Anybody have a way to find and fix permissions issues that is more of a bulk action? I assume that would involve the API.
  • External_Chris
    External_Chris Member Posts: 38 ✭✭
    Yes… sketch blocks please (begging you…) 😉
  • marianela
    marianela Member Posts: 20 ✭✭
    Yessss, Spanish Learning center!
  • bryan_lagrange
    bryan_lagrange Member, User Group Leader Posts: 1,041 ✭✭✭✭✭
    3 weeks have past…..Time for an F5 party!!!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Urs_Egger_REACT
    Urs_Egger_REACT Member Posts: 133 PRO
    @mlaflecheCAD is there a way to isolate the Altium Integration Video? Or maybe integrate the video as an Introduction in the Onhape Help Menu. I find it very helpful to showcase the capability of the connector. Could not find it elsewhere.
  • Urs_Egger_REACT
    @ry_gb thank you
