I'm new to Onshape.
robey_reed
robey_reed Member Posts: 4 ✭
edited July 24 in Community Support
I'm new to Onshape. I successfully imported my pdf's, but I'm having trouble importing them into front view, top view and side view.
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,267 PRO
    Do you mean as a visual guide for creating a model? If so, pdf doesn't work. It must be png or two other formats. Here is the help section on it:
    https://cad.onshape.com/help/Content/Sketch/insert_image.htm?Highlight=image
  • robey_reed
    I successfully imported my pdf's and Onshape converted them png's. But the "Insert Image" toggle doesn't let me import my png's, it just says "Insert a DXF or DWG file".
  • romeograham
    romeograham Member, csevp Posts: 782 PRO
    There's another button to Insert image:
    depending on your screen size, it will be in different menu locations. You can use search (Alt+C to search for "insert image") to find it quickly.
    This only shows when you are editing a sketch.
