where do I begin?
christopher_bethel
christopher_bethel Member Posts: 12 ✭
I have an idea to build a kinetic wave driven sea water Desalinization station. useing the kinetic motion of waves to produce both driving of the gear mechanisim and pumping of clean water to storrage. the portion that is submerged needs to be robust enough to survive extended periods in sea water so i think stainless steel would be the right material. the design i have in mind would be capable of rotating a conical plain 360 (full circle) while at the same time spinning multipal axis points in that plane. This assembly would be part of a system that could utilize a similar design like the shaft of a "Yankee Screwdriver" and there would also need plumbing and one way valves. I can draw crude scetches but have no rela skills and that is why i am here….any all help appreciated…Chris (cwbethel55@gmail.com) or @Christo00735375 / @BethelSr78105
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,960 PRO
    edited July 27 Answer ✓
    If you were wanting to learn it yourself, then this is the best place to start https://learn.onshape.com/
    The learning pathways will make you efficient and save you years of trial and error.
    If you are looking to hire an expert, then I suggest what @Keith_Rice mentioned.
    FYI: I'm one of the CADSharp consultants.
  • Keith_Rice
    Keith_Rice Member Posts: 13 PRO
    Chris, if you're looking for expert Onshape mechanical designers to help bring your idea to life then we offer such services. You can learn more here. I will send you an email as well. Cheers.
  • MichaelPascoe
  • christopher_bethel
    I'M sorry but my navigation skills are lacking…
