Fixing all parts in part studio
DMoroniDMoroni Member Posts: 2
I'm making a design using a few different circuit board components that I am importing in my project and then assembling together in an assembly. One of the boards I have as an IGES assembly, and when it is imported it creates a new part studio with ~100 parts. My problem is when I add that part studio to the assembly all of the 100 parts are not fixed to each other and able to move freely, so the circuit board IGES as a part studio is basically useless.
I've tried to combine all of the ~100 parts in the circuit board to make a single part, but it ends up freezing the browser. How can I make that part studio act as a single part when I bring it into an assembly?
  • pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    Merge all the bodies in the authoring tool before you export to IGES.
    @DMoroni You can import the entire part studio, then use SHIFT select to apply a Group mate.  Then it will move as one unit.  You could also Boolean them in the part studio if you like.
  • DMoroniDMoroni Member Posts: 2
    Thanks all! Unfortunately I don't have another authoring tool readily available so I can't alter any of the files I get. When I try to boolean the parts the system just crashes.
    Group mate sounds like it will do exactly what I need it to, thanks!
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 422 image
    @DMoroni, please use the "Feedback" button under the "?" menu in Onshape and report the crash issue you are having. We will get right on it.
    -John
    John Rousseau / VP, Technical Operations / Onshape Inc.
