Consecutive bends creeping closer
Hello
I am doing a sheet metal that is bent 5 times, each time with a 33mm flat section in between.
The bends are creeping exponentially closer together and does not keep to the line spacing.
Adjusting the hold line or the k factor has no effect.
How do I bend the sheet metal as indicated on the sketch?
Heat Shield V2 or
Would be easier to diagnose why this is happening if you shared the document where the problem is happening.
Almost! A forum bug means you need to wait a little for the link to work before you hit send!
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
It looks to me like you have cosine error. That's why each bend after the first is in the wrong place. I personally haven't used a sketch the way you did for sheetmetal, but I don't think its meant to be used in that way.
Here is your link: https://cad.onshape.com/documents/ce1275d7b8aed8eaee204590/w/b111c8852655344ceb16e2e2/e/f69982566544710bffa1055d
