Improvements to Onshape - November 20th, 2026
JeremyRegnerus
JeremyRegnerus Member, Onshape Employees Posts: 4 image
edited November 20 in New in Onshape
This release is about building smarter designs with less manual effort. Configure folder suppression lets you control a whole group of features with a single configuration input. The new Context Manager tab puts every in-context reference for a Part Studio in one place. You'll also find faster drawing cleanup, consistent file naming for batch exports, thread milling in CAM Studio, and more on Android and iOS.
PART STUDIOS
CONTEXT MANAGER TAB
Part Studios get a new Context manager tab in the right side panel that lists every context for the Part Studio in one place. See each context's assembly, named position, and affected parts at a glance. You can click on the reference assembly to switch to it, or right click on it to change the configuration or show and hide context instances. Out-of-date contexts are flagged so you know when to update, which is facilitated by an Update all out of context references button.
https://onshape.wistia.com/medias/ls15e1sm5i?embedType=web_component&seo=false&videoWidth=960
CONFIGURE FOLDER SUPPRESSION
Feature list folders can now be configured and suppressed as a unit. Configure suppression on a folder and it shows up as a single column in the configuration table, instead of one column per feature inside it. Suppressing a folder suppresses the folder itself rather than each child feature, so configured Part Studios with optional groups of features are much easier to build and maintain.
https://onshape.wistia.com/medias/e2ppv9tv3i?embedType=web_component&seo=false&videoWidth=960
HIGHLIGHT SKETCH ENTITIES ASSOCIATED WITH DIMENSION
When you hover over a sketch dimension, the entities it's attached to now highlight. This makes it easier to see and understand the design intent behind each dimension.
https://onshape.wistia.com/medias/3y1ucc307k?embedType=web_component&seo=false&videoWidth=960
ASSEMBLIES
HIGHLIGHT PARTS MISSING MASS FOR ASSEMBLY CENTER OF MASS
When you turn on center of mass in an assembly and one or more parts are missing mass properties, Onshape now selects those parts in the Instance list. Instead of a generic error, you can see exactly which parts need a material or mass override.
https://onshape.wistia.com/medias/rna12wm3jt?embedType=web_component&seo=false&videoWidth=960
SORT BOM BY MATERIAL OR APPEARANCE
The Bill of Materials can now be sorted by Material or Appearance. Group parts that share a material for purchasing and cut planning, or that share a finish for painting and coating, right from the BOM.
https://onshape.wistia.com/medias/5770rj6p2t?embedType=web_component&seo=false&videoWidth=960
DRAWINGS
MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER
You can now move multiple dimensions and annotations at the same time in Drawings. Window select or multi-select the annotations you want, including weld symbols and callouts, then drag one of the selected dimensions to move them all together. This makes it much faster to clean up a crowded view or make room for other annotations.
https://onshape.wistia.com/medias/57x1jgpqi3?embedType=web_component&seo=false&videoWidth=960
IMPORT / EXPORT
EXPORT RULES FOR PART STUDIO BATCH EXPORT
Export Rules are now applied when you batch export parts from a Part Studio as individual files. Each part in the .zip is named using your company's export rules, so files come out consistently named with part numbers, revisions, or other properties, with no manual renaming.
https://onshape.wistia.com/medias/4ex23xd8m2?embedType=web_component&seo=false&videoWidth=960
RENDER STUDIO
IMPROVED SELECTION HIGHLIGHTING FOR TEXTURES AND APPEARANCES
In Render Studio, selected faces and parts now switch from a solid fill highlight to an outline while the Appearance property panel or the Projector dialog is open. You can see exactly how a texture or appearance looks on the selected faces as you adjust it, without deselecting to check and reselecting to keep editing.
https://onshape.wistia.com/medias/6425kzlcf5?embedType=web_component&seo=false&videoWidth=960
CAM STUDIO
THREAD MILLING
CAM Studio now includes thread milling. Cut internal or external threads by circular interpolation using a single-point or full-length thread mill. You'll find it under Holes > Thread milling, with options for pitch, direction, passes, and lead-in and lead-out.
https://onshape.wistia.com/medias/jvnta8x6xe?embedType=web_component&seo=false&videoWidth=960
ROLLBACK BAR
CAM Studio now has a rollback bar in the job list, just like the feature list in Part Studios. Roll back to any point in a job to insert new toolpaths exactly where they belong in the machining sequence, instead of always adding them at the end.
https://onshape.wistia.com/medias/ct4qz60rff?embedType=web_component&seo=false&videoWidth=960
NEW MACHINES AND POST-PROCESSORS
The following machines and posts have been added:
  • Makera Carvera desktop CNC machines: Carvera Air, Carvera (C1), and Z1.
  • A post-processor for ProtoTRAK SMX controls, initially with the TRAK TMC5 ProtoTRAK-GCD machine.
  • A new generic Mitsubishi post-processor targeting the Mitsubishi M850 control, delivered as a 3-axis machine initially.
MOBILE
iOS: REDESIGNED NUMPAD
The numpad used when editing sketch dimensions on iOS has been redesigned to match current Onshape UI standards. It keeps the custom options you rely on, like tolerances and driving or driven dimensions, in a cleaner layout that's consistent with the rest of the app.
https://onshape.wistia.com/medias/enk0udwmtj?embedType=web_component&seo=false&videoWidth=960
iOS: ATTACH COMMENTS TO SKETCH DIMENSIONS
On iOS, you can now attach comments directly to sketch dimensions, just as you can on the web. Flag a critical dimension or explain why it's set the way it is, and your team sees the comment tied to that exact dimension.
https://onshape.wistia.com/medias/a07mc4wzjo?embedType=web_component&seo=false&videoWidth=960
ANDROID: PARTS LIST PROPERTIES, DRAWING COMMENT TAGS, INFO AND SHARE
Onshape for Android picks up three updates that bring it closer to the web. The Part Studio parts list can now show part number, revision, and state when Display parts list properties is turned on in your account preferences. Comments tagged to drawing views and annotations on the web now display as tagged on Android. Info and Share have also moved out of the right side panel, to the top right on tablets and to the bottom bar on phones.
https://onshape.wistia.com/medias/15d0c6uj1o?embedType=web_component&seo=false&videoWidth=960
LEARNING CENTER
NEW ARTICLES
We’ve published several new Learning Center articles. They cover data management, release workflows, and building better assemblies:
Please take a moment to try out these new features and improvements, and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new documents. Over the next few days, these features will also be available in documents created before this update.  Mobile improvements roll out in the days after the release and are updated via the Apple App Store or Google Play Store.
  • shawn_crocker
    shawn_crocker Member, OS Professional Posts: 1,075 PRO
    "MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER". I been waiting since 2020 for this.
  • Alex_Pitt
    Alex_Pitt Member Posts: 78 PRO
    Nice improvements! All look good - but especially love folder suppression, editing drawing annotations en-masse and export naming rules. Thank you!
  • john_mcclary
    Nice update, these are all very welcome improvements!
  • sebastian_glanzner
    sebastian_glanzner Member, Developers Posts: 500 PRO
    Nice updates!
    @shawn_crocker
    We got GTA VI before "MOVE MULTIPLE DIMENSIONS AND ANNOTATIONS TOGETHER".
  • eric_pesty
    Good to see some of these "overdue" things finally added:
    • Suppress folders in PS
    • Export rules applied on multiple parts at once
    The context manager looks like it will be quite useful too… The checkbox on isolate/transparent is also a nice improvement as using the ends of the slider was a bit goofy.
    Always good to see a long list of "fixed" items in the changelog too, that often gets overlooked because it's not as "shiny" as new features but it's really important!
  • aeromorrison
    aeromorrison Member Posts: 95 PRO
    Awesome quality of life improvements in this release. I'm particularly excited (oddly enough) about HIGHLIGHT SKETCH ENTITIES ASSOCIATED WITH DIMENSION.
  • bryan_lagrange
    bryan_lagrange Member, User Group Leader Posts: 1,052 ✭✭✭✭✭
  • photinos_design
    photinos_design Member Posts: 3 PRO
    Folder suppression is huge for my work! Thank you!
  • chara
    chara Member Posts: 1 EDU
    Nice to see more improvements to sketching!
  • Derek_Van_Allen_BD
    I saw the Master Model Workflows article earlier this week when I was training a new hire and all of my old links pointed to the new article. Nice to see Blob Modeling at the top of the list where it rightfully belongs, but a little disappointed that this version of the article is thinner on content for clicking through examples to see the pros and cons of each workflow.
    New guy's just gonna have to take me at my word that it's the only way to model.
  • Nick_Holzem
    Nick_Holzem Member Posts: 251 PRO
    edited November 20
    Happy to see branch from any history point is back! Noticed it immediately as I did this so regularly my habits never changed.
    Lots(!) of fixes in the change log. Looking forward to checking more of these.
    Context manager is sick. Looking forward to update all at once and leveraging configurations. Well developed at the first go.
    PS Folder Suppression = big win
  • christopher_dziuba
    christopher_dziuba Member Posts: 125 ✭✭✭
    'Highlight Sketch Dimensioned Entities" , " Move Multiply Drawing elements at once" and especially "Export Batch Rules" are HUGE improvements from my personal list!!! Incredible work!!
  • GWS50
    GWS50 Member Posts: 538 PRO
    Context Manager is a fantastic addition, as is Missing Mass in Assemblies. Absolutely marvellous, thank you
  • EvanReese
    EvanReese Member, Mentor Posts: 3,105 PRO
    I think folder suppression is the most exciting thing here for me. It will make it so much more intuitive and manageable to configure suppression of lots of features at once!
  • rick_randall
    rick_randall Member Posts: 444 ✭✭✭
    edited November 21
    Folder suppression - oh yeah!
    Best Practices for Managing Data in an Onshape Document was also informative
  • greg_matthew_crossley
    greg_matthew_crossley Member Posts: 2 ✭
    Makera Z1 support, nice!!
    S1mon Member Posts: 4,646 PRO
    Folder suppression and part studio bulk export naming are two that I have been advocating for a long time. So glad to see these finally show up.
    Moving multiple drawing annotations at once is one of those things I would have assumed was there, but I manage to avoid doing drawings enough that I hadn't noticed. Glad this is fixed.
  • Misael
    Misael Member Posts: 12 PRO
    Love the CONTEXT manager tab. All the improvements are welcomed, but this one… I can't wait to use it.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,967 PRO
    folder suppression is extremely helpful with more dynamic workflows! thanks team!
    nice looking context manager too, good to see improvements there.
  • adam_geary
    adam_geary Member, csevp Posts: 44 PRO
    I love to see CAM Studio becoming more and more like the standard UI in Onshape. That rollback bar will definitely be useful!
    That and highlighting sketch entities are some small changes that'll make big improvements!
  • nick_lumb
    nick_lumb Member Posts: 27 PRO
    I am also delighted to see this - I think I've been looking forward to it for at least eight years!
