Un removeable error.
Attempting to delete this "use" feature has failed. It originally projected a point from a previous sketch onto a new one but now its useless and just sits there.
  • robert_scott_jr_
    Should be able to just left click it and hit the delete key. You can also right click it which will bring up a menu with an option to delete. Have you tried either? - Scotty
  • eric_pesty
    You might have multiple broken "use" constraints on top of each other so it might look like delete isn't working if you are just deleting the one "on top".
    Use the constraints manager to delete all broken references at once.
