Extrude Though Extruded Surface
mr_deek
mr_deek Member Posts: 6 ✭✭
Hello,
Am I correct you can not extrude trough a surface?
Expected:
Make a cylinder, back extrude a face up half the object. Extruding trough the object should remove the surface and the object.
Example: See how the revolve cut does not remove the screws serface?
https://cad.onshape.com/documents/dd5ac8ae0b36b285cfd79615/w/46e69100a42f35da14afa10c/e/be5f60e1fa54c3b5dcdd84be
Thank you.
    Hi @mr_deek - a solid extrude/revolve will not affect a surface body - only solid bodies. If you want to cut a surface you need to create another surface and use split then delete the unwanted surface bodies (using the delete part command).
