Mapping an image to a face/surface
jim_sheen
Member Posts: 1 ✭
Is there a way to map a raster image (say a dial or a logo) onto a face? If not, any workarounds?
@jim_sheen If the face is planar (flat) you can use the sketch image command to insert. If the face is non planar there is no way currently to map the image.0
Guys, is there a way to either persist the image into the assembly, or add an image to a planar face within the assembly?0
Here's improvement to vote for:
https://forum.onshape.com/discussion/2718/decals-or-images-as-skins-on-solid-faces-or-surfaces
//rami1
