Circular pattern bug
zaron_gibson
edited April 2016 in Community Support
So the top left find was made by me and then I circular patterned it around the shaft. As you can see. two of them refused to fully build.
  • Narayan_K
    Narayan_K ✭✭✭
    @ zaron_gibson , Which type of pattern you used(feature/part/face)?
    If you used feature pattern then we have to check which end conditions you used for first blade.
    If possible please share the document and paste the URL here.
  • The most efficient way to pattern this particular shape would be to pattern the part using the intersect option.
