How can I tweak gear meshing?
jon_woellhaf
When I put two spur gears in a gear relation, the teeth usually don't mesh correctly.
How can I make them appear to mesh properly?
I have not been able to figure out how to do that.brucebartlett said:You can rotate one of the mate connectors until the gears line up.5
You can rotate one of the mate connectors until the gears line up.0
I have not been able to figure out how to do that.brucebartlett said:You can rotate one of the mate connectors until the gears line up.5 -
Got it! Thanks, Bruce.0
