Can a Tetrad shape be created by "sewing" four adjacent sketched triangles into a Body?
paul_sorensen
paul_sorensen Member, Developers Posts: 3 ✭
Can a Tetrad shape be created by "sewing" four adjacent sketched triangles forming a closed space into a Body?
Likewise, can a collection of closed faces be made into a Body?
  • daniel_splawski
    daniel_splawski Member Posts: 66 ✭✭
    I don't know about sewing four adjacent triangles together, but if you were to extrude one triangle and the use the extrude>intersection feature to remove the excess material I believe it would have the same result.
    NeilCooke Moderator, Onshape Employees Posts: 6,111 image
    No, there is no "sew" function for faces or sketches. You could (as suggested above) extrude a triangle with draft that would give you the same result.
