How do I make a line connecting two different sketches?
stephen_fisher
stephen_fisher Member Posts: 1 ✭
I made a drawing that has 12 sketches and i want to make a line connecting the vertices of two different sketches. If someone could answer quickly it would be much appreciated.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ stephen_fisher, You can create a plane using the two sketches so that plane should passes through both sketch and you can create line on that plane.
    Please refer below video,
  • owen_sparks
    Very nice explanation stephen_fisher. :)
    Another option would be the featurescript 3D spline tool. (Thanks Illya.) Less clicks and no plane to make, which may be good of bad depending on whether you'd want it later.
    Cheers, Owen S.
    HWM-Water Ltd
  • otaolafr
    otaolafr Member Posts: 113 EDU
    Cheers, Owen S.
    Hey owen,
    i couldnt find the featurescript you are talking about, could you please post the link? thanks
