Replace parts in an assembly
shai_perednikshai_perednik Member Posts: 56 ✭✭
edited July 2016 in Community Support
I mated 44 brackets to my main assembly only to realize I need to use that bracket but in a sub assembly as that bracket has multiple screws and nuts.
Is there a way I can replace all 44 instances with a different part or a sub assembly?
Or do I just delete all 44 and start over?
Thank you!
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    You can use replicate to quickly add all those screws.. and you could also move one bracket into subassy (RMB on part - move to new sub..) add screws and use replicate to add the rest of brackets with screws. Try it, it's very powerfull and intuitive feature.
    //rami
Howdy, Stranger!
