How to remove an imported image from sketch
henry_feldman
Member Posts: 136 EDU
So after importing an image of a part drawing into the background of a sketch, I made my sketch over it and now want to remove it from the sketch. My temporary workaround was simply to drag it way off to the side, as it is very hard to read the dimensions of my sketch's constraints with the busy drawing behind. Is there a way to remove it?
Select one of the bounding sketch entities (the construction rectangle) and hit delete.Senior Director, Technical Services, EMEA5
