Images visible through solid objects?
owen_sparks
edited August 2016 in Community Support
Hi folks.
I have some unwanted behaviour with an image and would like to ask if I'm doing anything wrong or if I've just hit upon a limitation in the current version of OS.
We have a crude test cabinet model with an image of the front of a power supply slapped on the front of a simple extrusion.
all is good so far:-
However if the view is rotated the image can be seen through solid objects...
This really isn't what I had in mind!  Is there a way I can fix or work around this problem?
Thanks,
Owen S.
HWM-Water Ltd
  • owen_sparks
    Thanks @3dcad, good point about the side projection, I'd not considered that.
    IR raised.
    Owen S
    HWM-Water Ltd
