Cant select from sketch with more than 3 layers
If I make a sketch with 3 elements covering the same area
everything works as expected, but if I let one area be covered by 4 elements like
I cannot select any elements/areas from this sketch when attempting to extrude.
Questions:
- Is there a good reason why I can only have 3 layers?
- Is there a good reason why the sketch is not marked as red in the left menu (as I imagine something should indicate that the sketch is creating trouble)
  • shanshan
    shanshan Member Posts: 147 ✭✭✭
    there have been no layer concept in sketch for onshape , I  am not sure if I  get your point , for me what you did is ok , please see the  video below:
  • mathias_wulff
    mathias_wulff Member Posts: 8 ✭
    Very interesting. You got the exact point.
    Hmmm...
     The problem was recreated in an existing document. I will investigate and return with more information.
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ mathias_wulff ,If possible please share your document with public and we can go through that.
