imported data
andrew_hicks
Member Posts: 7 PRO
I have been working on imported models from other platforms. What is the best way to wake the geometry up on the imported model so that i can then make the parts needed and insert them in a drawing and dimension them. at the moment some of the features are not being reconised in the drawing sheets. do i have to put the parts in a part studio and resketch them and dimension then insert into the drawing?
Have you tried use/project feature in sketch mode? It should find the geometry for recreation.
//rami6 -
I was wondering if that was how you went about it. I will see how it goes.5
//rami6 -
