How do I import different versions of a part in an assembly to view side by side.
This is a typical client/team review situation.  Perhaps there is a different approach but I can't see it.
  • EMBASSY_DESIGN
    EMBASSY_DESIGN Member Posts: 6 PRO
    Gents,
    thank you for this,  I had worked out something similar.  I had hoped to be able to contain an entire project within one document but the only way of having a 'assembly of versions' is to have a separate assembly document.
    I have a separate assembly that has snap-shots versions.  "Crescent Moon- review assembly" if you want to check it out (I don't know how to link yet)
    Fortunately I can import this 'review assembly' into the original document as another assembly tab and it will update as I add move versions to the review assembly (but I need to make a new version in the review assembly).  "Bowl- Crescent Moon 01" if you want to check it out.
    Many thanks.
    Michael
