How to extrude off of a curved face of an imported .step file part?
cael_liakos_gilbert
cael_liakos_gilbert Member Posts: 1 PRO
edited November 2016 in Community Support
I am trying to make a cap/cover for a particular part that has a curved surface. I received a .step file of the part and am trying to build off of it by selecting the face and extrude --> new to create the cover matching the curved geometry of the original part, but onshape wont let me.
Its curious, I can select all of the flat, geometric surfaces and extrude off of those, but not the curves for some reason. Any suggestions? Thanks!
  • bruce_williams
    Extrudes need planar faces (not curved) or a sketch regions as input.  It should be possible to create a plane and extrude up to part or face.  The 2nd direction allows some interesting results as well...
    www.accuratepattern.com
    Have you tried thicken?
