cant find how to use mm instead of inches
cant find how to use mm instead of inches.
it would stand by the properties
you can change this per document using hamburger menu > workspace units or you can set default units from the menu behind your name > manage account > preferences
and you can also mix unit simply by writing 25mm or 1" as value
//rami6
//rami6
