HowTo use Part Studio variables to select entry in a drop down field (annotion) in featurescript
wolfgang_maier
Member Posts: 39 ✭✭✭
Hello,
i am using the beam feature to build construction with several beams.
I want to put the size of the beam in a Part Studio variable.
With changing the variable all beams should be rebuild.
So the drop down field "size of the beam" in featurescript beam should be filled by my Part Studio variable...
regards
Wolfgang
regards
Wolfgang
That would not be possible because the beam profiles are generated from a lookuptable that is pre-populated with sizes. If the beams were generated from user input numbers (and therefore could possibly be non-standard sizes) then you could do it.Senior Director, Technical Services, EMEA0
