loosing relationships
rick_chapmanrick_chapman Member Posts: 24 PRO
I created an assembly with many parts and have them all mated but when I try to use this assembly in a larger one some of the parts loose their relationship and I am not able to put them back into place.
Is there something that I have forgotten to do in the process?
  • rick_chapmanrick_chapman Member Posts: 24 PRO
    Thanks guys, That helps I think. I redrew portion as an assembly paying better attention to the relationships. Once done I grouped them and seem to have them place in an upper level assembly just perfectly.
  • jackson_kingjackson_king OS Professional Posts: 80 PRO
    Good to hear @rick_chapman!  I have had the same issue as you described before and wasn't sure why it happened.  I try to use 'group' whenever I can because it seems to update well and saves me from adding a lot of mates.
Howdy, Stranger!
