Importing .dxf or .dwg
agustin_gonzalez
Member Posts: 5 ✭
Hi,
I succesfully upload same drawing in .dxf and .dwg format but cannot view/edit de drawings.
I've got no preview, either.
Same thing happens when importing .sldprt files.
Am I doing anything wrong?
Thank you in advance!!
Hi @agustin_gonzalez - when you import a valid file into Onshape it will be automatically translated into a new tab where it can be viewed.
Senior Director, Technical Services, EMEA0 -
Hi Neil!
Can I somehow copy/paste from that drawing to a sketch?0 -
Are there limitations for the uploaded files to be valid?
Thanks again!!0 -
Some of them (.dxf) are translated, others not.
.sldprt are never translated.
Is there any limit on the size?0 -
Hi Agustin, to import DXF into a sketch, upload the file then in a Part Studio create a new sketch and use the Import DXF button. SLDPRT files only translate solid or surface geometry not sketch geometry.Senior Director, Technical Services, EMEA0
