Using an editing logic function to drive multiple UI values
Lee_Hesketh
Lee_Hesketh Member, Developers Posts: 148 ✭✭✭
Hello all. Can one editing logic function be used to updated multiple changed values int the UI panel? If there are two values, let's say for simplicity's sake two length values, that are then changed in the code. Will both values be able to be updated or do ELF's only change one value?
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
  • ilya_baran
    The editing logic function can change multiple parameters.
    Please take a look at the Spur Gear example - that takes 3 values and modifies 2 of them based on the user editing the third.
  • Lee_Hesketh
    So I had a look and I got a little confused. How could I set a boolean that is defaulted to false to true and have it ticked in the UI?
