rotate pattern, remove
john_mariner
Member Posts: 6 PRO
I have a solid disk, added a radial slot. Need to make a pattern of the slots, but there is no separate "part" to select for removal. When creating the slot, the only option is to merge with the original part. How can I make a pattern remove?
Never mind, duh. Need to select feature pattern. Solved0
I would also take a look at performing a face pattern. Performance-wise, this is the better option0
