rotate pattern, remove
john_mariner
john_mariner Member Posts: 6 PRO
edited February 2017 in Community Support
I have a solid disk, added a radial slot.  Need to make a pattern of the slots, but there is no separate "part" to select for removal.  When creating the slot, the only option is to merge with the original part.  How can I make a pattern remove?
  • john_mariner
    Never mind, duh.  Need to select feature pattern.  Solved
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    I would also take a look at performing a face pattern. Performance-wise, this is the better option
    Twitter: @bradleysauln
