Sheet metal: square holes are OK but round holes fail.
nicholas_allen
Member Posts: 1 ✭
I'm designing a box in sheet metal.
If the various cutouts are defined after the finish-sheet-metal, all is OK except that they do not appear in the flat pattern.
If the cutouts are defined before the finish-sheet-metal, the round holes fail but the square ones are OK and appear in the flat pattern.
Why?
Why?
Can you share your Document?Senior Director, Technical Services, EMEA0
I think the sheet metal feature still have its limitations, you can't use the feature hole with the sheet metal active. You can finish it and insert the hole later but it does not appear in the flat pattern. Other things you can't do is a fillet in the corners (usually to prevent harm when handling the part).
Give it time to Onshape to improve it further but for now either you make a hole by drawing a sketch and extrude removing it or use Boolean operations like in the demonstration video.1 -
Hello Nicholas,
Here is a linked document. So far I haven't had any problems extruding features from the sheet metal model converting to the flat layout.
If you want feel free to share your document.
https://cad.onshape.com/documents/d954b1edbad6eb348f43bf1c/w/9b448a7c4236fd341ed9cb1a/e/c180d0f0309db017c812b01f
Stay awesome and have a great week!
Sincerely,
Chris Winters1
