Making a corkscrew
bao_nguyen
Member Posts: 3 ✭
Hi!
I just started using Onshape and I love it. But I have trouble making the end part of the corkscrew, the spiral. Would appreciate any help.
To make the sharp tip you can either loft to a point or just extrude the flat face with draft.1
I'm in hurry, so I just tip you with the tools create helix wire and sweep along that. Cut the end to desired shape if needed.
Create in parts and use boolean to combine.//rami2 -
Oh man! thank you. I will try0
