How do I edit a basic sketch?
tony_upton
tony_upton Member Posts: 1 ✭
I have followed the instructions and can produce a (for example) rectangle in a particular plane. I can extrude the rectangle in all planes, but the system will not allow any other editing/modifying; eg, holes, fillets or extensions. What am I doing wrong?
  • brian_jordan
    brian_jordan Member, Developers Posts: 145 ✭✭✭
    In the feature list on the left of the screen you will see your sketch listed, probably as "Sketch 1". Right clicking on this will open a menu the second item of which is "Edit...". Selecting this will open the sketch for further editing.
  • Jake_Rosenfeld
    You can also double click any feature in the feature list to edit it (as a shortcut instead of right click > "Edit...")
  • brian_jordan
    @Jake_Rosenfeld Thanks - that one had passed me by.
