Building a model using variable
mladen_sudar
mladen_sudar Member Posts: 3 ✭
edited April 2017 in Community Support
Can model be created with variables A,B,C,D... and that variables to be controlled with like excel spreadsheet or similar? And then going through rows model will adjust? Is this possible and if Yes can You explain how?
  • 3dcad
    edited April 2017
    Yes and no. Yes you can create variables and control model with those but no you can't drive them using a spreadsheet.
    Look at Onshape help for variables, there's also really cool way to create 'option variable' that let's you quickly select different set of variables.
    Use feedback to add ticket for spreadsheet driven vars, that is definitely needed (though I would prefer google sheets over excel)
    //rami
  • Jake_Rosenfeld
