How can I create string variables?
daniel_bailey
daniel_bailey Member Posts: 7 ✭
edited April 2017 in Community Support
I have a featurescript feature that takes a string as a precondition.
Is it possible to define a variable that is a string that I can pass into this feature?
I've tried setting the value of a variable to be something quoted in double quotes and single quotes, neither of these is accepted.
  • konstantin_shiriazdanov
    as far as I know you can't set string value to a part studio variable, but you can pass to feature script the name of a variable as string
  • daniel_bailey
    Hmm, okay then, I've added the feature request tag. This would be really useful for me.
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,278 image
    There is work in progress to remove the type restrictions on variables, so our intent is that you will be able to use strings, arrays, maps, even functions (lambdas).
  • owen_sparks
    Now that is splendid news.  Thankyou :)
    Owen S.
    HWM-Water Ltd
  • leon_poot
    leon_poot Member, Developers Posts: 87 ✭✭✭
    @ilya_baran Lambda functions in variables... this sounds fun!
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams, Mostly Harmless
  • ilya_baran
    @leon_poot You can already put a lambda into a variable with a custom feature.  What we plan to add is the ability to put it in a variable in a Part Studio directly.
  • john_mcclary
    nice
    will that mean we can have logical if statements (if..else..while) inside the variable's lambda function?
    or is the lambda function limited?
    I've rarely used lambda's in C#, so they are still kinda short hand (in-line) tricks to me...
  • ilya_baran
    The lambda can contain arbitrary FeatureScript code (so yes, if-else, loops, variables).  Though if you are going to be defining non-trivial lambdas, I would recommend putting them in a custom feature, like this: https://cad.onshape.com/documents/9307925f33961a9f1b10c559/w/8cd40e21db8c1060b315e72f/e/0801bef9707f10c6cf75635f
